Maytag top loader LAT9356AAE. Agitator lifts up during filling and/or washing cycle and will not agitate clothes. I can push entire piece back down and it will engage and work for a load or 2. Eventually it lifts up again, a couple of inches and will not agitate. When machine is empty, I can lift agitator completely out (very easily) and there is some type of transmission fluid or oil on center rod. Not sure where to start to fix, please help:(
Was thanked: 3 time(s) in 3 post(s)
There is a locking screw on a side of the agitator (#16 on the diagram). You will need a 1/4" nut driver or a socket wrench to tight it. If it got lost, then you have to order one. - The locking screw Part number: AP4026393
[FONT='Times New Roman']When the agitator lifts up does the shaft and everything lift out of the transmission? If so there is a plastic clip on the shaft that is broken. If this is the case I will give you info on the repair. If only the agitator is lifting up (not the shaft) replace the setscrew that Gene posted. [/FONT]
Rank: Guest
The agitator and shaft lift
