Coreycrew
#1 Posted : Thursday, January 26, 2012 10:43:47 AM(UTC)
Coreycrew
Maytag top loader LAT9356AAE.
Agitator lifts up during filling and/or washing cycle and will not agitate clothes. I can push entire piece back down and it will engage and work for a load or 2. Eventually it lifts up again, a couple of inches and will not agitate. When machine is empty, I can lift agitator completely out (very easily) and there is some type of transmission fluid or oil on center rod.
Not sure where to start to fix, please help:(
#2 Posted : Thursday, January 26, 2012 2:36:08 PM(UTC)
There is a locking screw on a side of the agitator (#16 on the diagram). You will need a 1/4" nut driver or a socket wrench to tight it. If it got lost, then you have to order one.
- The locking screw Part number: AP4026393
applianceman
#3 Posted : Thursday, January 26, 2012 7:40:06 PM(UTC)
applianceman
[FONT='Times New Roman']When the agitator lifts up does the shaft and everything lift out of the transmission? If so there is a plastic clip on the shaft that is broken. If this is the case I will give you info on the repair. If only the agitator is lifting up (not the shaft) replace the setscrew that Gene posted. [/FONT]
Guest
#4 Posted : Tuesday, April 6, 2021 8:42:57 AM(UTC)
Guest
Rank: Guest
Groups:
United States
The agitator and shaft lift
Guest
#5 Posted : Thursday, March 24, 2022 11:43:03 AM(UTC)
Guest
Rank: Guest
Groups:
United States
Hello, I'm having this issue agitator and shaft lifts entirely. What is the part number for the plastic clip.
