Rank:: Member
I was dispensing ice, and had held down lever for a while. It beeped, and stopped dispensing. Now the light over the water/ice buttons is out. And the light indicating auto/on over the light switch is also out. None of these same functions will now work. If I push the dispense lever it now beeps, and does nothing else. The ice maker is now full, so water is still being supplied to the unit. Is there a fuse? Ideas?
Originally Posted by: Tater Salad I was dispensing ice, and had held down lever for a while. It beeped, and stopped dispensing. Now the light over the water/ice buttons is out. And the light indicating auto/on over the light switch is also out. None of these same functions will now work. If I push the dispense lever it now beeps, and does nothing else. The ice maker is now full, so water is still being supplied to the unit. Is there a fuse? Ideas? just checking I have same problem depressed water for a while then same thing happened did you figure this out?
