Tater Salad
#1 Posted : Sunday, January 22, 2012 11:30:39 AM(UTC)
Tater Salad
I was dispensing ice, and had held down lever for a while. It beeped, and stopped dispensing. Now the light over the water/ice buttons is out. And the light indicating auto/on over the light switch is also out. None of these same functions will now work. If I push the dispense lever it now beeps, and does nothing else. The ice maker is now full, so water is still being supplied to the unit. Is there a fuse? Ideas?
grandriverat
#2 Posted : Tuesday, February 19, 2013 5:05:55 PM(UTC)
grandriverat
just checking I have same problem depressed water for a while then same thing happened did you figure this out?
