buldog9
#1 Posted : Wednesday, January 18, 2012 11:45:18 AM(UTC)
buldog9
Hello all, My washer started with the DL code, so I replaced the door lock mechanism, which then it worked for 3-4 wash cycles, now it is displaying the F 11 code, I find that there is an intermittant connection at the PC board located on top and rear of unit, if I wiggle connector or hold connector tight to board, unit will work. If I let go, unit stops working and code flashes.My question is, do you think replacing the board will fix this? My next attempt will be to try and clean contacts, if possible. I am hesitant to just buy board as it is $240.00. Thanks for any help on this.
sidfink43
#2 Posted : Friday, January 20, 2012 4:55:22 PM(UTC)
sidfink43
That almost certainly sounds like the problem is with the board.
The good news, if you buy from this site and the part does not fix the problem you can return it. As long as the problem is not at the connector end I am thinking a new board will solve your problem.
Guest (4)
