wkooist
#1 Posted : Tuesday, January 1, 2008 9:39:22 AM(UTC)
wkooist
4 year old gas oven (Amana ACS3350) has intermittent problems of delayed start with noticable gas smell. I have read a similar thread on the same problem and oven, but with no gas smell. A new ignitor was the solution. Is this also the likely solution for my repair, or does the gas smell suggest something different?
#2 Posted : Wednesday, January 2, 2008 9:20:53 AM(UTC)
If it smells gas only when you try to use the oven, then most likely the problem is a bad oven igniter. The igniter sold without the mounting bracket. You can use the old one or you can buy it separate.
- The part number for the oven bake igniter is AP172397
- The part number for the mounting bracket is AP174418
- Here are the break down diagrams for the Amana range Model ACS3350AB
Good luck.
wkooist
#3 Posted : Wednesday, January 2, 2008 5:34:26 PM(UTC)
wkooist
Perfect! Thanks.
