tdibrin
#1 Posted : Sunday, July 12, 2009 2:30:08 AM(UTC)
tdibrin
Is there some kind of adjustment for the water inlet valve. I have good pressure, no blocked lines, and still get hollow cubes. I have replaced everything twice. Cubes do not make it through the entire ice maker. Hollow and only filling first four slots. I have tried leaning the ice maker downslope, and there is no water still reaching end of ice maker. Does the refridgerator have anything to do with the function of the ice maker. I have bled the lines to get air out as well.
woodchuckie
#2 Posted : Sunday, July 12, 2009 4:04:09 AM(UTC)
woodchuckie
Rank:: Advanced Member
No adjustment for the inlet valves, only on the ice maker. Some have an adjustment behind the plastic cover marked -/+ which you would turn toward the +.
Does it flow through good when you swap the wires on the water inlet valve and try the water dispenser.
Have you checked the pressure at the valve or are you talking about just your house water pressure.
There may be a screen filter just before the valve which can get clogged.
tdibrin
#3 Posted : Monday, July 13, 2009 1:47:12 AM(UTC)
tdibrin
No screen filter that I can see. Pressure in house and when I did bucket test was good. Checked water shut off valve and it was not restricted. I finally switched the wires and have solid cubes. Thanks. Can you tell me why that makes a difference. I appreciate the help.
tdibrin
#4 Posted : Monday, July 13, 2009 1:48:27 AM(UTC)
tdibrin
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Water inlet valves burning out (Dishwasher Repair)
by Tydinelle 3/3/2024 4:06:06 PM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Whirlpool Water Inlet Valve Repair for Leak (Refrigerator & Freezer Repair)
by ForumUser1 12/23/2023 12:57:44 PM(UTC)
Water Inlet Valve WR57X10033 / AP3189335 for General Electric DTL18ICSRRBS (Refrigerator & Freezer Repair)
by breckrider 1/18/2023 7:43:17 PM(UTC)
Replaced water inlet valve, still no ice or water (Refrigerator & Freezer Repair)
by Guest 7/3/2021 3:14:08 PM(UTC)
dishwasher not filling with water...already changed water inlet valve (Dishwasher Repair)
by jbonez 5/25/2021 5:32:22 PM(UTC)
Leaky new water inlet valve on whirlpool gold refrigerator (Refrigerator & Freezer Repair)
by Guest 4/4/2021 5:35:03 PM(UTC)
Water Inlet Valve for Whirlpool WRF560SEYW05 (Refrigerator & Freezer Repair)
by nycgene 7/30/2020 10:50:55 AM(UTC)
Noise after water inlet valve replacement (Refrigerator & Freezer Repair)
by Kristsivia 11/3/2019 4:29:36 PM(UTC)
GE washer replace WH13X10057 water inlet valve (Washer Repair)
by Cmath 3/9/2017 9:23:21 AM(UTC)
Water inlet valve (Washer Repair)
by dcbradt 3/8/2017 4:02:37 AM(UTC)
Water inlet valve leaking (Washer Repair)
by Jimh64 1/29/2016 7:31:50 AM(UTC)
Hot to replace water inlet valve on GE washer dryer combo WSM2700HCWWW? (Washer Repair)
by AbbyBrickman 1/4/2016 8:36:24 PM(UTC)
