While washing some rugs, the machine went off balance real bad. Took it apart and the hub is completely broken. Small pieces in machine and also it has a hole in it now. How difficult is this to replace and could what other parts do I need when replacing the hub. thanks
are you talking about beige plastic part under agitator ? it connects to transmission shaft by bolt.
this is the part under the agitator. It is about 10 1/2 inches in diameter and is made of metal. It is completely distroyed and the part is called "the hub". thanks
