Lolo133
#1 Posted : Tuesday, January 1, 2008 8:02:43 AM(UTC)
Lolo133
While washing some rugs, the machine went off balance real bad. Took it apart and the hub is completely broken. Small pieces in machine and also it has a hole in it now. How difficult is this to replace and could what other parts do I need when replacing the hub.
thanks
misterfixall
#2 Posted : Tuesday, January 1, 2008 9:38:31 AM(UTC)
misterfixall
are you talking about beige plastic part under agitator ? it connects to transmission shaft by bolt.
Lolo133
#3 Posted : Wednesday, January 2, 2008 4:24:31 AM(UTC)
Lolo133
this is the part under the agitator. It is about 10 1/2 inches in diameter and is made of metal. It is completely distroyed and the part is called "the hub".
thanks
