tmenter1
#1 Posted : Tuesday, January 1, 2008 7:20:30 AM(UTC)
tmenter1
i just replace the motor & pump i turn it on the water fill up
then wait for the motor to on then heard a click waited to see it start
nothing then i push cancel/ drain then motor started ran for 10 second
then stop
i replace because the other one was leaking & the motor burnt out it started to smoke
#2 Posted : Tuesday, January 1, 2008 11:56:24 AM(UTC)
You may have jammed something in the pump, just take apart and check. If ok, you may need to check your winding current per the schematic, could be a start relay/timer problem.
