seal
#1 Posted : Saturday, July 11, 2009 10:34:21 AM(UTC)
seal
It's a 5 yrs unit, stop turning while hot air still blowing.
It stay silent while hot air is blowing. Definitely not drying my wet cloths.
I opened up the unit and found the schematic and thermal fuse, but I don't know how to check whether it's the motor is bad or just the thermal fuse.
Any tips would be appreciated.
thanks,
Seal
seal
#2 Posted : Saturday, July 11, 2009 10:36:50 AM(UTC)
seal
BTW, all panel electronics control works perfectly, there is not lose wires. I checked the continuity from the switch to the thermal fuse, no problem.
hints or what I should do next? should I just replace the unit or it is worth fixing it?
