It's a 5 yrs unit, stop turning while hot air still blowing. It stay silent while hot air is blowing. Definitely not drying my wet cloths.
I opened up the unit and found the schematic and thermal fuse, but I don't know how to check whether it's the motor is bad or just the thermal fuse.
Any tips would be appreciated.
thanks, Seal
BTW, all panel electronics control works perfectly, there is not lose wires. I checked the continuity from the switch to the thermal fuse, no problem.
hints or what I should do next? should I just replace the unit or it is worth fixing it?
