Washer stopped spinning, smell burnt rubber. Replaced both belts July 2011. worked fine till this week, same problem. Is there an adjustment? Springs to replace? If one of those is the fix do I need new belts again?
Maytag has a repair kit available that will solve your problem,it is a spring and roller replacement kit that mounts to the bottom of the motor plate,the part # Part number: 205000
Originally Posted by: appliance pro  Maytag has a repair kit available that will solve your problem,it is a spring and roller replacement kit that mounts to the bottom of the motor plate,the part # Part number: 205000
is available and costs $11.00 also replace the belts again part # Part number: 2111124
Put roller kit and new belts on. Machine works in wash cycle but does not work in "spin cycle". The tub does not spin at all, the belt starts to smell like burnt rubber. Any thoughts? Thanks
