toony
#1 Posted : Wednesday, January 11, 2012 7:24:18 PM(UTC)
toony
My elements are shot, I need to replace the 8 inch and 6 inch. I have found a 4 turn 8 inch that is 2100 watt. I see that the original element is a 2500 watt. can I replace the 8 inch element with the 4 turn 2100 watt element? The 6 inch is a 3 turn element, and the original is a 4 turn element 1500 watt. I'm assuming that the 3 turn 6 inch is rated less than 1500. They look like they will fit my stove. they are made by Frigidare. Can I replace with the lower wattage elements? :confused:
#2 Posted : Thursday, January 12, 2012 5:20:34 AM(UTC)
Why not use the correct elements?
What you have to match up are the male ends on the elements so they fit/connect correctly into the element's receiver.
Also how the element supports itself on the drip tray can be important.
Replacement parts for WHIRLPOOL RF379LXKQ0 FREE STANDING - ELECTRIC | AppliancePartsPros.com
AP3031500 - 6 inch 4 turn 1500W
AP3134976 - 8 inch 5 turn 2600W
AP4700137 - 8 inch 5 turn 2100W
whirlpool element replacement (Oven Repair (including Ranges and Cooktops))
by hdebby 5/21/2008 12:36:47 PM(UTC)
