The refrigerator door will not seal completely without manually pushing the door closed. Seal on the door is good, looking to replace the door cam part # AP2058495. Do you think that this will fix my problem.
Yes, that is the likely problem. . Watch the operation of the door to see if it rises up when opened. IF not, that's your problem To install it Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips. Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
