CTHEESFELD
#1 Posted : Friday, July 10, 2009 6:30:11 AM(UTC)
CTHEESFELD
The oven would not go on one day. The broiler and stove top worked. Then the next day, the oven came on but after that it would not. I replaced the computer board and it still will not come on. Now I think it is the Oven Igniter. Any thoughts?
Dan O.
#2 Posted : Friday, July 10, 2009 7:05:49 AM(UTC)
Dan O.
That could be a possibility depending on the result of more detailed observations made of it during an outage. It is glowing? not glowing??
You can read about how common gas oven ignition systems work and the observations and tests necessary to start diagnosing problems with them at the following link:
LINK > Understanding Gas Oven Ignition Systems
JFYI
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Frigidaire wall oven model CGEB30S8CS1 oven will not turn on (Oven Repair (including Ranges and Cooktops))
by RHykawy 4/2/2021 2:00:36 PM(UTC)
GE Profile electric oven will not turn on (Oven Repair (including Ranges and Cooktops))
by toddlamp 3/31/2021 7:03:39 PM(UTC)
Frigidaire Gallary Electric Range Oven Will Not Turn On (Oven Repair (including Ranges and Cooktops))
by jaycevs 12/2/2014 5:28:35 AM(UTC)
Jenn-air double wall oven - lower oven will not turn on (Oven Repair (including Ranges and Cooktops))
by hjustice 9/28/2014 11:37:55 AM(UTC)
GAs range oven will not turn on (Oven Repair (including Ranges and Cooktops))
by JohnRogers 4/18/2013 8:21:57 AM(UTC)
Oven will not turn on (Oven Repair (including Ranges and Cooktops))
by Bkomperda 2/6/2013 2:59:00 PM(UTC)
Maytag oven will not turn on (Oven Repair (including Ranges and Cooktops))
by threeputt 12/10/2012 12:07:16 PM(UTC)
Need to bake/ oven will not turn on! (Oven Repair (including Ranges and Cooktops))
by ms michelle 1/24/2011 3:05:15 PM(UTC)
Oven Will not Turn On (Oven Repair (including Ranges and Cooktops))
by pete8960 3/25/2010 7:47:46 AM(UTC)
Frigadiare Oven will not turn on (Oven Repair (including Ranges and Cooktops))
by 29264 3/17/2010 10:58:24 AM(UTC)
by mcarp 9/25/2009 3:28:57 PM(UTC)
Kenmore gas oven will not turn ON (Oven Repair (including Ranges and Cooktops))
by skidoomxz99 8/20/2009 3:42:25 PM(UTC)
by rortega 7/11/2009 9:15:43 AM(UTC)
Oven will not turn on, broiler works, stove top works (Oven Repair (including Ranges and Cooktops))
by caewart 6/19/2009 4:31:43 PM(UTC)
by craigjung 3/1/2009 1:21:19 PM(UTC)
