kperki
#1 Posted : 16 years ago
kperki
I have the above gas range and the display panel is not working, only a couple of things. I can't even change temps etc. with the oven. The front looks fine. The tech from Sears came and he said I had to change the whole thing, control and control panel and w/ labor its over $700.00. When I checked on their part site I saw the parts come in two parts. He acted like it was one. Does anyone know do they both have to be changed? Does the control panel get damaged when you change the control? I felt like he was trying to scam me and when I called on the phone with them they were very nasty and I think I would rather not give them my money. Any help on this would be appreciated. Oh and it is the downdraft and I can not use that because that button doesnt work either...Thanks
Dan O.
#2 Posted : 16 years ago
Dan O.
Are you saying just some of the buttons don't respond as opposed to the "display" (aka LEDs) not lighting up?
Please clarify the problem symptoms.
Yes the electronic control and the control panel are separate parts.
Only if both are defective or you didn't want to bother trying to figure out which one might be the actual cause. Replacing 'everything' is sure to cure the problem?
Not usually, no.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
kperki
#3 Posted : 16 years ago
kperki
Thanks for the help. The buttons on the display panel do not work, only a few do. The leds work with the buttons that do work. If I order the control is this something that I can change myself by just removing some screws and taking out the old one and putting in the new?
Thanks again
Kris
Dan O.
#4 Posted : 16 years ago
Dan O.
Quote:
The buttons on the [control] panel do not work, only a few do.
That would most often be caused by a problem in the control panel's keypad requiring the whole control panels to be replaced.
LINK > Jenn-Air JGS9900BDS Control Panel (no picture)
I have no idea of your abilities but most reasonably handy homeowners should be able to replace such a part. No special tools should be required.
JMO
Dan O.
=D~~~~~~
gne_norris
#5 Posted : 16 years ago
gne_norris
I've had my Jenn-air (Jgs8750adb) for 3 years and have needed to replace the control panel 3 times. I was told that it is caused by heat .... note: control panel is just above the oven door! Now they are telling me that the part is not available and for $278, they will install a replacement stove. I've spent $675 already on repair costs (labor not included in warranty) so now I'll be $950 over what I shelled out when I bought this piece of junk in 2006! My choice is to shell out $278 more or go out and buy a stove for $500 or more. This range should have been recalled.
