gigo4u
#1 Posted : Tuesday, July 7, 2009 3:56:35 PM(UTC)
gigo4u
I have a Kenmore refridgerator model 596.71103101 bottom freezer and I need a wire diagram in order to put all the wires back together. The wires were cut because of vandalism. Does anyone have a wire diagram or photos of how the wire harnesses should be installed will be great help.
Drags1998
#2 Posted : Tuesday, July 7, 2009 4:17:37 PM(UTC)
Drags1998
The wires should be color coded. just match up the colors and splice them back together.:)
gigo4u
#3 Posted : Tuesday, July 7, 2009 4:51:08 PM(UTC)
gigo4u
Hi Drags1998,
Thanks for your reply, I wish that was the case. All the wires were cut from the harness control and only portions of the wires are left behind. I would not know where each wire goes to. Only with a wire diagram would give a clue.
