I have a Kenmore refridgerator model 596.71103101 bottom freezer and I need a wire diagram in order to put all the wires back together. The wires were cut because of vandalism. Does anyone have a wire diagram or photos of how the wire harnesses should be installed will be great help.
The wires should be color coded. just match up the colors and splice them back together.:)
Hi Drags1998,
Thanks for your reply, I wish that was the case. All the wires were cut from the harness control and only portions of the wires are left behind. I would not know where each wire goes to. Only with a wire diagram would give a clue.
