mr1022
#1 Posted : Monday, January 2, 2012 11:27:21 AM(UTC)
mr1022
Maytag gas dryer LSG7904AAE takes over two hours to dry a small load. The igniter will glow for a few seconds and then gas will come through ok to make a blue flame but then the flame shuts off after 15 seconds and doesn't come back on for a few minutes. So there's heat, but not enough of it to dry a load in a reasonable amount of time.
Any suggestions? Thanks so much for any help you can give.
ApplianceJunk
#2 Posted : Monday, January 2, 2012 11:49:27 AM(UTC)
ApplianceJunk
Probably one of the two coils on the gas valve is at fault.
mr1022
#3 Posted : Monday, January 2, 2012 12:09:43 PM(UTC)
mr1022
I will order both now and see if that fixes the problem. Thanks so much!
Guest (4)
