JADREPAIR
#1 Posted : Saturday, December 31, 2011 11:14:24 AM(UTC)
JADREPAIR
I have a Frigidaire dishwasher model PLD2855rfc1. The unit is not filling with water. The water valve is open. I also checked the screen filter at the inlet valave. All is clear. Can you provide any recommendations?
#2 Posted : Monday, January 2, 2012 4:53:39 AM(UTC)
Here are your parts.
Replacement parts for FRIGIDAIRE PLD2855RFC1 Frigidaire/dishwasher | AppliancePartsPros.com
How do you know that the water inlet valve is open or are you referring to the water shut off valve in the plumbing?
If the water inlet valve is open then there must be a plug between it and the inlet port on the side of the dishwasher tub. I have never see a plug here.
Does the valve get 120 volts when it is supposed to open.
If not check the overflow mechanism. Could be the float is stuck in the up position so that the switch is not activated and the unit thinks it is already over filled.
If it does get 120 volts and there is not a plug upsteam of the valve then I would replace the valve.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
