ppiazzola
#1 Posted : 17 years ago
ppiazzola
My Kenmore dishwasher has no power. An electrician checked the breaker and the connections and there is power to the Electronic Control Assembly. The Electronic Control Assembly was replaced and still no power. The dishwasher was working great before the loss of power. Ideas?
#2 Posted : 17 years ago
Need model # to help. Look for a thermal fuse that plugs into the electronic module, probably blown.It is a white sort of square thing.
rjs wf tx
#3 Posted : 17 years ago
rjs wf tx
I had the same problem with my Whirlpool dishwasher model: DU1100XTPB7. Replaced the thermal fuse and it fixed the problem; however, one month later I'm having the same problem...no power. I suspect the fuse is not the problem because it's doing what it is supposed to do. The question is why is it blowing...why is circuit overheating?
Thanks,
Randy
#4 Posted : 17 years ago
I suspect a power surge blew the fuse.Or it could be a timing error from the electronic module. You might want to confirm by checking the current draw at different periods of the wash/drain/heating cycle. If ok you might want to wire in a surge protector.
Frigidaire FFHB2740PS2 No Power (Refrigerator & Freezer Repair)
by mnjeepmale 9 months ago
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 10 months ago
kenmore elite smartheat quietpak 9 control has no power (Dryer Repair)
by Guest about a year ago
Gdf520pgj2ww dishwasher no power (Dishwasher Repair)
by pbajr 2 years ago
GDF610PMJ5ES (GE Dishwasher) - No Power to LED Display (Dishwasher Repair)
by txwildcard 2 years ago
GE JVM1540DM5WW suddenly no power a few seconds into starting it. (Microwave Repair)
by Guest 2 years ago
Fridge - No power (Refrigerator & Freezer Repair)
Thermador t18id900lp no power (Refrigerator & Freezer Repair)
by whosurpopi 2 years ago
No power to ice and water in Frigidaire FFHS2311PFEA (Refrigerator & Freezer Repair)
by Slbno1 2 years ago
lg tromm dryer no power (Dryer Repair)
by Guest 3 years ago
Frigidaire FGHS2631PF4A No Power (Refrigerator & Freezer Repair)
by hpreston35 3 years ago
GE Dishwasher - No Power - Replaced Control Board, Wiring Harnes, and UI Board (Dishwasher Repair)
by aervin 3 years ago
No power or panel lights to GE Dryer (Dryer Repair)
No power to control panel Kenmore Elite dishwasher model 665.12793k311 (Garbage Disposer Repair)
by John Boof 3 years ago
Maytag washer no power (Washer Repair)
