dsergent@hemc.net
#1 Posted : Friday, July 3, 2009 2:32:09 PM(UTC)
dsergent@hemc.net
I tried to clean the oven and code F2-E1 appeared. The manual said to press Cancel, and then if error returns after 60 sec replace keypad. I do not have a cancel key. How do I Cancel??
Dan O.
#2 Posted : Saturday, July 4, 2009 12:28:34 PM(UTC)
Dan O.
Quote:
How do I Cancel?
The owner's manual says:
"GBD307PDQ7 Owner's Manual" wrote:
To reset the clock, press UPPER OFF or LOWER OFF on double oven models. On single oven models, press OFF/CANCEL.
So I would assume those buttons would be the equivalent.
That is only available already mounted to the control panel (see the following link).
LINK > Whirlpool GBD307PDQ7 Control Panel & Keypad Asm., White
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Thermador double oven from '99 troubleshoot (Oven Repair (including Ranges and Cooktops))
by mike_balt 5/6/2024 4:16:42 PM(UTC)
Maytag Double OVen Model MGR6875ADW- Igniter wont stop ticking (Oven Repair (including Ranges and Cooktops))
by gnieciag 10/15/2023 1:53:42 PM(UTC)
Maytag MGR6875ADW Double Oven - Burner top (Oven Repair (including Ranges and Cooktops))
by gnieciag 8/29/2023 5:38:52 PM(UTC)
removing cooktop control panel on LG double oven (Oven Repair (including Ranges and Cooktops))
by Hurdles 4/4/2023 11:41:26 AM(UTC)
KitchenAid KEBC208KBT03 Superba Double Oven F5-E1 (Oven Repair (including Ranges and Cooktops))
by ericpeterson 1/9/2023 5:45:49 PM(UTC)
Jennair double oven (Oven Repair (including Ranges and Cooktops))
by JennairOven 12/8/2022 3:30:24 PM(UTC)
KitchenAid double oven - broiler working, oven won't warm (Oven Repair (including Ranges and Cooktops))
by jcz24 11/28/2022 5:53:17 AM(UTC)
Whirlpool Double oven diagnostic mode (Oven Repair (including Ranges and Cooktops))
by webjunk78230 8/29/2022 1:37:43 PM(UTC)
Frigidaire FGET2765PWE Wall Double Oven (Oven Repair (including Ranges and Cooktops))
by innesmd 7/1/2022 3:28:51 AM(UTC)
1970 GE electric wall oven (double oven) broken temperature sensor (Oven Repair (including Ranges and Cooktops))
by zea3 6/21/2022 1:48:00 PM(UTC)
Whirlpool double oven RBD305PVS02 no display, no heat, lights work (Oven Repair (including Ranges and Cooktops))
by Guest 1/5/2022 7:05:37 AM(UTC)
Whirlpool Double Oven, RBD305PRS00, no display, oven dead (Oven Repair (including Ranges and Cooktops))
by steveg_nh 12/31/2021 7:23:33 AM(UTC)
Jenn Air Double Oven Malfunctioning (Oven Repair (including Ranges and Cooktops))
by Guest 12/27/2021 3:48:46 PM(UTC)
GE Double Oven Displays 'F97' Error Code (Oven Repair (including Ranges and Cooktops))
by Chainplate 12/2/2021 9:13:32 AM(UTC)
Double Oven- both fail to reach full tempo (Oven Repair (including Ranges and Cooktops))
by Guest 9/28/2021 2:38:45 PM(UTC)
