Water dispenser does not shut off - keeps dripping, any ideas?
You have been a member since:: 3/10/2009(UTC) Views messages in topic : 1,363
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
