carpool
#1 Posted : Tuesday, December 27, 2011 10:52:01 PM(UTC)
carpool
I've got an oven that will no longer bake or broil (but the cooktop is fine). This is a recent problem.
Also, the child lock feature stopped working. This happened a couple months ago.
Any ideas on how to isolate if this is a 'control board' problem or a 'power board' problem?
Cheers,
Kevin
ApplianceJunk
#2 Posted : Wednesday, December 28, 2011 5:01:52 AM(UTC)
ApplianceJunk
The tech sheet shows a inline fuse on the wiring diagram for the bake/broil relay. I would check that fuse first.
carpool
#3 Posted : Wednesday, December 28, 2011 11:45:14 AM(UTC)
carpool
Thanks for the tip - I see the following link is describing what you say:
http://appliancejunk.com/forums/index.php?topic=2315.msg8282#msg8282
Do you know what part that would be? I can't figure out which one it is from here:
Oven replacement parts for WHIRLPOOL KESC307HWH8 ELECTRIC RANGE | AppliancePartsPros.com
Cheers,
Kevin
Jenn Air Range/Convection oven won't bake or broil (Oven Repair (including Ranges and Cooktops))
by Pamwest 11/30/2015 11:09:20 AM(UTC)
Oven won't bake or broil (Oven Repair (including Ranges and Cooktops))
by ConnerNA 9/30/2012 5:05:45 AM(UTC)
Oven won't bake or broil no error showing (Oven Repair (including Ranges and Cooktops))
by jallen 2/2/2009 6:48:53 AM(UTC)
GE Gas Oven won't bake or broil... (Oven Repair (including Ranges and Cooktops))
by ssacrf 6/2/2008 6:13:24 PM(UTC)
GE Electric Double Wall Oven won't bake or broil (Oven Repair (including Ranges and Cooktops))
by tjp 10/27/2007 8:06:52 AM(UTC)
