Fridge Is Making A Pumping Noise And The Temperature Readings In Fridge Are Not Reading Now??? Compressor Maybe?
Open up the back of the fridg and check for something loose. Measure the freezer and fridg. temperatures and post.
Originally Posted by: richappy  Open up the back of the fridg and check for something loose. Measure the freezer and fridg. temperatures and post. Found fan not turning and motherboard is making the clicking noise - temperatures in fridge have dropped to nothing now
Remove the cover over the motherboard in the back, remove the 3 pin power connector and run a jumper from pin marked line to comp. If your compressor now runs, you have a bad motherboard AP4297272.
