ShannonLHall
#1 Posted : Wednesday, July 1, 2009 1:23:57 PM(UTC)
ShannonLHall
Fridge Is Making A Pumping Noise And The Temperature Readings In Fridge Are Not Reading Now??? Compressor Maybe?
#2 Posted : Wednesday, July 1, 2009 2:06:25 PM(UTC)
Open up the back of the fridg and check for something loose. Measure the freezer and fridg. temperatures and post.
ShannonLHall
#3 Posted : Wednesday, July 1, 2009 3:49:38 PM(UTC)
ShannonLHall
Found fan not turning and motherboard is making the clicking noise - temperatures in fridge have dropped to nothing now
#4 Posted : Thursday, July 2, 2009 12:17:18 AM(UTC)
Remove the cover over the motherboard in the back, remove the 3 pin power connector and run a jumper from pin marked line to comp. If your compressor now runs, you have a bad motherboard AP4297272.
