unit is less than 2 years old. but has seen alot of use. Yesterday it Worked like a champ, crushed ice for 1 of 2 glasses, glass number 2 - was a no go. pushing the selector switch, you hear a small motor noise, as if something is shifting, but when to depress the paddle switch<-- what ever its called? N O T H I N G.
I have have looked over the drawings you have for the GS6NBEXRS00, is it the circuit board or the motor, how do you test? Thanks in advance
try cleaning out bin. clean drive under bin. start with fresh ice
I have removed the entire unit and checked for lose wire, disconnect anything. No Luck. I have to assume that either the control board or the motor is fried - question is how to know which is the problem?
