Where is the water valve and how do I install new one.
It's on the back of the unit where the water supply comes in. Cut water off. disconnect water lines and unplug wires. Unscrew bracket from frame and put the new one on. If you have a line with screw on connectors, the new one may come with quick connect fittings. You will need to cut the end off of your threaded fitting line and then just push it firmly into the new valve.
Hey, thanks for the info. Clay
