toymaker
#1 Posted : Tuesday, June 30, 2009 9:49:35 AM(UTC)
toymaker
Where is the water valve and how do I install new one.
woodchuckie
#2 Posted : Tuesday, June 30, 2009 11:42:32 AM(UTC)
woodchuckie
It's on the back of the unit where the water supply comes in. Cut water off. disconnect water lines and unplug wires. Unscrew bracket from frame and put the new one on. If you have a line with screw on connectors, the new one may come with quick connect fittings. You will need to cut the end off of your threaded fitting line and then just push it firmly into the new valve.
toymaker
#3 Posted : Tuesday, June 30, 2009 12:22:47 PM(UTC)
toymaker
Hey, thanks for the info. Clay
