have no heat! dryer runs, but no heat.bought(from you) and replaced new coils( great video!). but no heat. what do I check next?
Originally Posted by: tom pasternak  have no heat! dryer runs, but no heat.bought(from you) and replaced new coils( great video!). but no heat. what do I check next? Tom, Did you check for the burner ignition process, igniter comes on and glows "white hot", then cycles off, fades and the gas is ignited. You'll need a multimeter Part number: AP3873826
So you can check all the thermostat(s) and fuses, for a closed circuit at room temperature, and you may need to run a voltage check at the gas valve or timer, as well. Here's some meter usage information, if you need it : http://forum.appliancepartspros...continuity-ohmmeter.htmlGood Luck, :) :) :)
