tom pasternak
#1 Posted : Thursday, December 22, 2011 2:18:49 PM(UTC)
tom pasternak
have no heat! dryer runs, but no heat.bought(from you) and replaced new coils( great video!). but no heat. what do I check next?
Joe / APP Team
#2 Posted : Friday, December 23, 2011 6:38:20 AM(UTC)
Joe / APP Team
Tom,
Did you check for the burner ignition process, igniter comes on and glows "white hot", then cycles off, fades and the gas is ignited.
You'll need a multimeter
Part number: AP3873826
So you can check all the thermostat(s) and fuses, for a closed circuit at room temperature, and you may need to run a voltage check at the gas valve or timer, as well.
Here's some meter usage information, if you need it :
http://forum.appliancepartspros...continuity-ohmmeter.html
Good Luck,
