3 Pages123>
KULTULZ
#1 Posted : Wednesday, December 21, 2011 11:49:59 PM(UTC)
KULTULZ
There is occasionally (more frequent day by day) a clicking noise from the rear of the refrigerator. It sounds to me as a relay trying to kick in. It will make the noise for awhile (usually after door opening/closing) and then quit. During theses episodes, the temp displays will either not show or blink.
Any help appreciated.
THANX!
#2 Posted : Thursday, December 22, 2011 3:07:57 AM(UTC)
Check your model #
KULTULZ
#3 Posted : Thursday, December 22, 2011 7:20:28 AM(UTC)
KULTULZ
PDS20MCRBB
Serial No. MG051153
#4 Posted : Thursday, December 22, 2011 8:32:45 AM(UTC)
Remove the motherboard cover in the back, if it's the motherboard clicking, replace it as it will eventually fail AP4436216
KULTULZ
#5 Posted : Thursday, December 22, 2011 1:43:22 PM(UTC)
KULTULZ
thanx!
Anna's Mom
#6 Posted : Monday, January 23, 2012 9:01:20 AM(UTC)
Anna's Mom
Originally Posted by: KULTULZ Go to Quoted Post
thanx!
hello - did this work for you ? I have the same issue, same fridge, and almost the same serial # !! Let me know - thanks !
KULTULZ
#7 Posted : Tuesday, January 24, 2012 9:55:57 PM(UTC)
KULTULZ
Mom... ;)
Mine suddenly stopped making the noise so I have not replace the board (I'm cheap).
With my luck it will ignite leading to a meltdown destroying half of the neighborhood... :(
Say HI! to Anna for me... :D
#8 Posted : Wednesday, January 25, 2012 12:39:18 AM(UTC)
If you can't afford a new board, I would locate the clicking relay by fealing each one, the big one is the compressor relay, the small one, the defrost. Then remove the cover with sharp wood chisel, then try to clean the contacts with fine emory paper, or just order a new one. Flush the relay out with non-residue contact cleaner available at Wall Mart.
KULTULZ
#9 Posted : Thursday, March 8, 2012 5:09:15 AM(UTC)
KULTULZ
:confused: OK... I ignored the warning signs and advice. The noise returned but not as loud. Chose to ignore (another intelligent move). The freezer is still holding temp but the upper section is warm and showing fifty degrees...
Could this be as a result of the board failure or has the damage progressed?
This seems to be the case. Is this replacement Part No Genuine GE? The character sequence seems to be different from GE Service Parts.
#10 Posted : Thursday, March 8, 2012 10:04:03 AM(UTC)
That is this site's proprietary part #.
GE Profile Refrigerator Clicking noise (Refrigerator & Freezer Repair)
by RHoward24 4/4/2014 1:06:09 PM(UTC)
KitchenAid refrigerator clicking noise and fan short cycling (Refrigerator & Freezer Repair)
by jp65 5/17/2013 6:17:05 AM(UTC)
refrigerator clicking noises (Refrigerator & Freezer Repair)
by RandyT 11/25/2009 10:36:07 AM(UTC)
3 Pages123>
