The turntable makes a grinding sound, seems to struggle, but will not turn. Turning the coupler manually feels smooth. I can find 2 different motors for this unit- a drive motor and a stirrir motor. They are part numbers WB26X10037 and WB26X10038. Can you suggest which is the correct motor?
The turntable motor is shown as #43 on the diagram. - The APP part number for the turntable motor is AP2024962Gene.
Gene, thank you - I see in the part description it says, that I may have a D, or a square shaped shaft. I guess I better remove the old motor before and view the shaft before I order?
Originally Posted by: Gene  Yes, you are right.
Gene. It was the "D" shaft - part on order. Thanks!
Great news. The part arrived within 24 hours. within 5 minutes, i had it installed and operating flawlessly :)
Glad to hear it. Thank you for feed back.
