PoggiPJ
#1 Posted : Sunday, June 28, 2009 6:28:26 PM(UTC)
PoggiPJ
The turntable makes a grinding sound, seems to struggle, but will not turn. Turning the coupler manually feels smooth. I can find 2 different motors for this unit- a drive motor and a stirrir motor. They are part numbers WB26X10037 and WB26X10038. Can you suggest which is the correct motor?
#2 Posted : Sunday, June 28, 2009 6:56:19 PM(UTC)
The turntable motor is shown as #43 on the diagram.
- The APP part number for the turntable motor is AP2024962
PoggiPJ
#3 Posted : Monday, June 29, 2009 6:08:46 AM(UTC)
PoggiPJ
Gene, thank you - I see in the part description it says, that I may have a D, or a square shaped shaft. I guess I better remove the old motor before and view the shaft before I order?
#4 Posted : Monday, June 29, 2009 9:57:56 AM(UTC)
Yes, you are right.
PoggiPJ
#5 Posted : Tuesday, June 30, 2009 9:54:25 AM(UTC)
PoggiPJ
Yes, you are right.
It was the "D" shaft - part on order. Thanks!
#6 Posted : Tuesday, June 30, 2009 5:09:48 PM(UTC)
PoggiPJ
#7 Posted : Thursday, July 2, 2009 8:44:59 PM(UTC)
PoggiPJ
Great news. The part arrived within 24 hours. within 5 minutes, i had it installed and operating flawlessly :)
#8 Posted : Thursday, July 2, 2009 9:37:45 PM(UTC)
Glad to hear it. Thank you for feed back.
