zepeda
#1 Posted : Sunday, June 28, 2009 5:32:19 PM(UTC)
zepeda
My washer the other day wouldn't drain the water from the tub. There was a grinding noise coming from the lower pump attached to the drain hoses. But also the timer control was making a loud noise also. The pump appears to be spinning when the washer is on but it won't release the water from the tub. Any suggestions on what may be the problem. Is it the pump or would it be the timer control not closing anything when it should? Please any suggestions or experience with this problem would be much appreciated.
Tragically Tragic
#2 Posted : Sunday, June 28, 2009 7:58:27 PM(UTC)
Tragically Tragic
I would take the hoses off the pump and make sure there is nothing inside jamming up the pump impellor.
Frigidaire washer won't drain (Washer Repair)
by luckeyjim 2/11/2011 12:48:04 PM(UTC)
Frigidaire Washer won't drain and spin (Washer Repair)
by Tru2Chevy 7/20/2010 1:37:27 PM(UTC)
Frigidaire Washer Won't Drain (Washer Repair)
by Clutch 12/25/2009 1:17:10 PM(UTC)
Frigidaire washer won't drain/spin (Washer Repair)
by christylowe 12/6/2009 5:58:28 AM(UTC)
