Clutch
#1 Posted : Friday, December 25, 2009 1:17:10 PM(UTC)
Clutch
During a recent move, my Frigidaire front-loading washer was dropped about a foot down a stair. I feared the worst but was relieved when it started right up when I hooked it up at my new place. My relief quickly went away, though, when I realized the washer would not stop filling with water and would not drain. I turned it off and on but it would just continue filling every time and not drain. I did this until it was about 3/4 full with water and about to bust out the door. I think I tried to set the program to spin/drain and it did not drain then either. Any ideas?? Thanks in advance!!
#2 Posted : Friday, December 25, 2009 8:43:58 PM(UTC)
Would it stop filling if you unplug the washer?
If it would, replace the pressure switch (#17 on the diagram).
- The pressure switch Part number: AP3874367
Frigidaire washer won't drain (Washer Repair)
by luckeyjim 2/11/2011 12:48:04 PM(UTC)
Frigidaire Washer won't drain and spin (Washer Repair)
by Tru2Chevy 7/20/2010 1:37:27 PM(UTC)
Frigidaire washer won't drain/spin (Washer Repair)
by christylowe 12/6/2009 5:58:28 AM(UTC)
by zepeda 6/28/2009 5:32:19 PM(UTC)
