THE ICEMAKER STOP WORKING. THE GREEN LIGHT WORKS. ITS COLD SEAMS TO BE LEAKING AND ICES UP ON THE TOP OF THE TRAY. CAN YOU HELP ME TRY AND REPAIR IT THANK YOU TOM:confused:
There is a tube coming into the icemaker that delivers water to the icemaker, check to see if it is stopped up with ice. If so, remove all the ice and replace the water valve. Refrigerator repair guide
