carlmurphy
#1 Posted : Sunday, June 28, 2009 7:17:24 AM(UTC)
carlmurphy
we had a thunderstorm and the power went out for a few minutes when it came back on the clock and timer on the stove no longer lights up everything else on the stove works is there a fuse or some type of reset or do i have to replace it
Dan O.
#2 Posted : Sunday, June 28, 2009 12:49:52 PM(UTC)
Dan O.
Quote:
the clock and timer on the stove no longer lights up everything else on the stove works.
Either no power is getting to the clock or it is likely defective.
Quote:
is there a fuse?
There is not usually a fuse for just the clock unit, no.
The only 'reset' that can usually be tried is totally disconnecting power from the appliance for a minute or two.
If the clock is receiving power but not functioning at all, yes it would usually require replacing.
LINK > Frigidaire FEF322BAWC Clock Unit
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
