Jarhead72
#1 Posted : Saturday, June 27, 2009 7:28:56 AM(UTC)
Jarhead72
Kenmore model dryer 110.60212990 turns off about 10-15 minutes into timed drying cycle. This cycle is high heat. Dryer works well on low heat auto dry but not in high heat. initial thought was a thermostat in dryer that was cutting off when dryer got to hot since it works on the lower heat setting. Any suggestions...Thanks
magician59
#2 Posted : Saturday, June 27, 2009 8:43:42 AM(UTC)
magician59
If you have a meter or continuity tester, test the thermostats. It is generally suggested that if you replace one t stat, you should replace them all.
Gas Dryer turns off early (Dryer Repair)
by giorfido 12/31/2022 8:36:38 AM(UTC)
Dryer Turns off in less than 30 seconds. (Dryer Repair)
by GalyonGal 4/7/2018 2:56:42 PM(UTC)
Whirlpool dryer turns off when using high heat (Dryer Repair)
by SheepNutz 6/24/2017 8:00:00 PM(UTC)
Dryer turns off (Dryer Repair)
by lmkot 3/5/2017 9:39:46 PM(UTC)
Dryer turns off mid cycle and then turns itself back on (Dryer Repair)
by acosto04 12/24/2012 1:19:34 PM(UTC)
dryer turns off after few minutes (Dryer Repair)
by jpstep 6/19/2012 12:33:45 PM(UTC)
Whirlpool Dryer turns off (Dryer Repair)
by AHESCOBEDO75 8/25/2011 5:23:26 PM(UTC)
Dryer turns off after 10 min (Dryer Repair)
by clarence ray 12/31/2010 2:26:48 PM(UTC)
Dryer turns off after a few seconds (Dryer Repair)
by Tanzee 12/15/2010 1:32:13 PM(UTC)
by llano339 11/3/2010 3:57:46 PM(UTC)
Dryer turns off autmatically in TIMED mode but not the others, delicate, cotton etc. (Dryer Repair)
by Rawbert 1/15/2010 3:15:58 PM(UTC)
dryer turns off and won,t restart for about an hour (Dryer Repair)
by captainda 12/6/2009 5:48:35 AM(UTC)
dryer turns off before cycle complete (Dryer Repair)
by AmyC 5/1/2009 1:24:09 PM(UTC)
gas dryer turns off(timer runs) re starts on own?? (Dryer Repair)
by efniatet 12/7/2008 6:21:27 PM(UTC)
