Kenmore model dryer 110.60212990 turns off about 10-15 minutes into timed drying cycle. This cycle is high heat. Dryer works well on low heat auto dry but not in high heat. initial thought was a thermostat in dryer that was cutting off when dryer got to hot since it works on the lower heat setting. Any suggestions...Thanks
If you have a meter or continuity tester, test the thermostats. It is generally suggested that if you replace one t stat, you should replace them all.
