I just replaced rear and front glides and belt. THe dryer is still noisy. The drums turn feely, i hear something loose when I turn like there something inside the drum lose, but the drum is empty. Would the idler pulley cause this or is the motor going? thanks
Almost every time I work on a GE (that's who made yours) dryer over 5 years old, the rear bearing is failing and must be replaced. If you did not examine it when you replace the other parts, take out the drum and take a look. Here are your parts Replacement parts for GE NWSR483GB2WW | AppliancePartsPros.comIf it is ok, you have essentially won the GE dryer lottery, and can then check further to see if it is your idler pulley or the motor. The pulley is your next best bet. Good luck, let us know what you find out.
