Pattianne
#1 Posted : Thursday, January 8, 2009 5:37:56 PM(UTC)
Pattianne
My Maytag dryer still works fine but from the moment I turn it on and the
tub starts to tumble it sounds like a car with blown bearings. It getting louder with each use. Could really use some advice on this.:confused:
Thanks,
Pattianne
#2 Posted : Friday, January 9, 2009 1:38:23 AM(UTC)
Here is your parts breakdown
Model LDE6914ACE
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16008714.pdf
Often a rumbling is the rear support bearings.
Open it up and check and replace as necessary the following
Rear support roller bearings and shafts
Idler roller and shaft
Also while open you might as well check/replace the following
Front glides
Drum seals
Belt
Blower Wheel
Give the interior a good cleaning including the blower wheel
While you are at it clean and check the vent system
You basically when finished will have an overhauled unit.
Pattianne
#3 Posted: : Friday, January 9, 2009 4:01:03 PM(UTC)
Pattianne
Thanks for the info denman sure sounds right and very helpful. I really appreciate your advice.
Pattianne :)
Kenmore Gas Dryer Noisy When Hot (Dryer Repair)
by atetra 3/21/2013 6:46:11 PM(UTC)
Dryer noisy (Dryer Repair)
by Jags 11/11/2012 3:02:18 PM(UTC)
Maytag Dryer Noisy when starting (Dryer Repair)
by jpw050 5/24/2010 6:22:07 AM(UTC)
Dryer Noisy (Dryer Repair)
by foxk49 6/25/2009 5:46:20 PM(UTC)
dryer noisy, leaves black marks (Dryer Repair)
by vsbonner 7/20/2008 2:55:43 PM(UTC)
dryer noisy, leaves bladk marks (Dryer Repair)
by vsbonner 7/20/2008 2:52:36 PM(UTC)
