evaporator motor stop working, i replace the motor but the new motor only work for a second and stop and continue like that, i notice there is not enough air going through the duct to the refrigerator side. How i test the evaporator motor to see if there is something else wrong with the refrigerator.
the voltage going to the fan is 120 but is intermittent coming and going every two second. how do i test the adaptive defrost control
I do not know how to test them. Sometimes you can see a burnt, discolored or corroded area that's bad.
