batu
#1 Posted : Thursday, June 25, 2009 12:52:22 PM(UTC)
batu
evaporator motor stop working, i replace the motor but the new motor only work for a second and stop and continue like that, i notice there is not enough air going through the duct to the refrigerator side.
How i test the evaporator motor to see if there is something else wrong with the refrigerator.
woodchuckie
#2 Posted : Friday, June 26, 2009 6:31:24 AM(UTC)
woodchuckie
Check the voltage going to the fan. Should be 120. Problem may be adaptive defrost control part 23(f23) on diagram 2. Replacement parts for FRG FRS26BH6CB4 | AppliancePartsPros.com
batu
#3 Posted : Sunday, June 28, 2009 2:25:25 PM(UTC)
batu
the voltage going to the fan is 120 but is intermittent coming and going every two second.
how do i test the adaptive defrost control
woodchuckie
#4 Posted : Sunday, June 28, 2009 3:48:12 PM(UTC)
woodchuckie
I do not know how to test them. Sometimes you can see a burnt, discolored or corroded area that's bad.
batu
#5 Posted : Saturday, July 4, 2009 8:46:08 AM(UTC)
batu
thanks a lot. I order the adaptive defrost control part 23(f23) on diagram 2. Replacement parts for FRG FRS26BH6CB4 | AppliancePartsPros.com. Replace it,and the refrigerator is working fine, thank a lot again.
