robo1961
#1 Posted : Thursday, June 25, 2009 12:29:24 PM(UTC)
robo1961
If anyone has been keeping up with my saga, here's the final outcome.
My dryer would only run while the start switch was held on. I traced the problem to a faulty idler switch. This switch acts as a safety if your belt breaks. When tension drops off of the idler pulley the switch opens up and your dryer won't run. I checked the switch with a continuity meter and the held the leads together and let the dryer run.
Now here's why I'm posting my comments:
My local appliance parts supplier wanted to sell a replacement switch to me for $68.00. Online they go for anywhere from $50 to $75.
Since there is absolutley nothing special about this switch, I went looking elsewhere.
I found the EXACT same switch at my local Grainger Supply house for...
$3.24
If anyone else has this same dryer problem, please don't get caught overpaying for a switch that can be bought elsewhere for about 1/20th of the cost.
sidfink43
#2 Posted : Thursday, June 25, 2009 2:29:17 PM(UTC)
sidfink43
Hi Robo
Just wanted to say thank you for sharing your diagnosis and repair with us. It is not often we see a failed broken belt switch, so your post was very illuminating and instructive.
Thanks again, and good luck with your dryer
