gene.royer
#1 Posted : Thursday, June 25, 2009 8:31:40 AM(UTC)
gene.royer
Kenmore 790.9641240, while using stove top power burner (front left) a loud pop was heard and I thought I saw a blue flash (like an arc) above the pan, the next day received a slight electrical tingle after turning plastic switch ON for right front burner, and again a loud pop (no apparent arc). Secured circuit breaker, opened the top backplane of the stove and found charring on the Simmer Select (P/N 316429301) and Cooktop Lockout (P/N 3164181__). Checked for grounds, by jumpering neutral and hot lead, measuring continuity w/multimeter across jumpered leads and return lead, and cycling stovetop switches to ON/OFF position. No measurable continuty was read. Ordered new Simmer Select and Cooktop Lockout boards. Is there anything else I should check before or after installing new boards?
Dan O.
#2 Posted : Thursday, June 25, 2009 10:45:44 AM(UTC)
Dan O.
Quote:
Model Number: 790.9641240
That model number is incomplete or incorrect.
Quote:
Is there anything else I should check before installing new boards?
Other than shorts to ground and/or poor connections, I can't think of anything.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
gene.royer
#3 Posted : Thursday, June 25, 2009 11:01:13 AM(UTC)
gene.royer
I used the whole part number (790.9641240) I found on some documentation delivered with range. The front cover of the Kenmore Electric Range Use & Care Guide indicates model 790 with several series (i.e. 9621*, 9622* etc.) mine happens to be 9641*; hence, I probably should refer to the part number as 790.9641.
Sincerely,
Dan O.
#4 Posted : Thursday, June 25, 2009 9:28:40 PM(UTC)
Dan O.
Quote:
I used the whole [model] number (790.9641240) I found on some documentation delivered with range.
Documentation rarely has the complete information. The complete information will usually only be found right on the appliance's model and serial number identification tag. It is the only reliable place to get it anyway.
Possibilities for what you originally supplied include:
790.96412400
790.96412401
790.96412403
790.96412404
790.96412406
790.96412407
790.96412408
790.96412409
790.9641240A
790.9641240B
790.9641240C
790.9641240D
790.9641240E
You can find tips for locating the actual model and serial number identification tag on your appliances at the following link:
LINK > Model Number Tag Location Guide
It is a model number not a part number and the above is even more incomplete than the first. You would be best to only use the complete information as found right on the appliance's identification tag.
JFYI
Dan O.
=D~~~~~~
