2 Pages12>
garymatt@optonline.net
#1 Posted : Wednesday, December 26, 2007 1:40:45 PM(UTC)
I can not get the machine tub to spin. The Motor works, I just replaced the Belt but I can not turn the Tub or the Agitator. I can not get a good grip on the pulley to try and turn it. Is there a way to test the transmission? When I had it running the cluth
#2 Posted : Wednesday, December 26, 2007 2:04:19 PM(UTC)
Most likely the problem with your washer is a bad transmission.
The transmission as long as the clutch are no longer available.
#3 Posted : Wednesday, December 26, 2007 2:25:39 PM(UTC)
Is there any way to definitly check the transmission?
#4 Posted : Wednesday, December 26, 2007 2:39:05 PM(UTC)
If you can not turn the pulley it means the transmission is locked up.
#5 Posted : Wednesday, December 26, 2007 2:41:03 PM(UTC)
Shine a bright lite in the spin basket and look for something caught. Also pull the tub cover off and check for something there.
If ok, pull the belt off the tranny pulley and turn it in the spin direction. If it is locked up, you have a bad tranny. Possibly a frozen spin bearing, just check tub seal area above tranny. Post results.
#6 Posted : Wednesday, December 26, 2007 2:49:41 PM(UTC)
How can I tell if the Transmission is bad or if the brake is holding the tub from spinning?
#7 Posted : Wednesday, December 26, 2007 2:54:39 PM(UTC)
Also I should tell you that there is alot of oil under the machine
#8 Posted : Wednesday, December 26, 2007 5:24:09 PM(UTC)
There are no separate breaks in this washer. It's time for a new one.
#9 Posted : Wednesday, December 26, 2007 6:41:58 PM(UTC)
The brake shoes are built into the tranny, no way to tell if tranny or brakes.
#10 Posted : Thursday, December 27, 2007 8:30:56 AM(UTC)
I checked what you asked and I see nothing blocking the Tub. I am on the phone with a local repair man and he is looking to see if a tranny is available
Tub will not spin on spin cycle? (Washer Repair)
by Mike@castlerockis.com 2/13/2012 4:07:22 PM(UTC)
Tub Will Not Spin (Washer Repair)
by eddienlynn 5/16/2011 6:36:15 AM(UTC)
Tub will not spin (Washer Repair)
by mentorsince89 9/19/2009 8:12:43 AM(UTC)
2 Pages12>
