My Bosch dishwasher had been running fine, then it stopped in early wash cycle. Checked electricity at fuse and plug, no problems. I can't restart it using control wheel settings or buttons. Any help would be appreciated!
I have the same problem. It stopped mid-cycle, flooded with water, and will not go back on, even though I scooped out all the water. Any help would be greatly appreciated!
Originally Posted by: tom johnson My Bosch dishwasher had been running fine, then it stopped in early wash cycle. Checked electricity at fuse and plug, no problems. I can't restart it using control wheel settings or buttons. Any help would be appreciated! Remove the toe panel and check the power cord connection to the dishwasher for a burned wires. The model number you posted does not come up. The closest model I found is Replacement parts for BOSCH SMU2042 UC/09 (FD 7307-7504) | AppliancePartsPros.comGene.
Originally Posted by: cgebhart44 I have the same problem. It stopped mid-cycle, flooded with water, and will not go back on, even though I scooped out all the water. Any help would be greatly appreciated! What is the complete model number of the dishwasher? Gene.
It's model # SHX36L05UC/18
I checked everything that was suggested and couldn't find anything so I had a repairman come over. He said the wires in the door that bend everytime the door is open had shorted out. He fixed them and now it works fine. Anyone who wants to take the door apart and knows how to fix wiring could save some money! I don't and I didn't!
