tom johnson
#1 Posted : Thursday, June 25, 2009 6:05:20 AM(UTC)
tom johnson
My Bosch dishwasher had been running fine, then it stopped in early wash cycle. Checked electricity at fuse and plug, no problems. I can't restart it using control wheel settings or buttons. Any help would be appreciated!
cgebhart44
#2 Posted : Thursday, June 25, 2009 9:18:12 AM(UTC)
cgebhart44
I have the same problem. It stopped mid-cycle, flooded with water, and will not go back on, even though I scooped out all the water. Any help would be greatly appreciated!
#3 Posted : Thursday, June 25, 2009 2:06:48 PM(UTC)
Remove the toe panel and check the power cord connection to the dishwasher for a burned wires.
The model number you posted does not come up. The closest model I found is Replacement parts for BOSCH SMU2042 UC/09 (FD 7307-7504) | AppliancePartsPros.com
#4 Posted : Thursday, June 25, 2009 2:07:46 PM(UTC)
What is the complete model number of the dishwasher?
cgebhart44
#5 Posted : Thursday, June 25, 2009 2:55:39 PM(UTC)
cgebhart44
It's model # SHX36L05UC/18
#6 Posted : Thursday, June 25, 2009 8:50:03 PM(UTC)
Make sure there is 120 VAC to the dishwasher.
Remove the toe panel and check the power cord connections to the dishwasher.
Check the door latch and the door switch. Check the "on-off" switch.
Post the results.
Here are the breakdown diagrams for Replacement parts for BOSCH SHX33A02 UC/14 (FD 8211-) | AppliancePartsPros.com, model similar to yours.
tom johnson
#7 Posted : Friday, June 26, 2009 2:04:55 PM(UTC)
tom johnson
I checked everything that was suggested and couldn't find anything so I had a repairman come over. He said the wires in the door that bend everytime the door is open had shorted out. He fixed them and now it works fine. Anyone who wants to take the door apart and knows how to fix wiring could save some money! I don't and I didn't!
Guest (4)
Bosch stops mid cycle (Dishwasher Repair)
by dqwick 12/15/2009 10:48:46 PM(UTC)
